Like Tree3Likes
Xray T4 2016
    Hide Wikipost
Old 03-17-2017, 02:10 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Xray T4 2016
Last edit by: R Dodge
Welcome to the XRAY T4'16 Thread & Wikipost! Here you will find some useful info, tips and tricks as well as setups that are used by several team drivers. This wikipost is a work in progress and should continue to develop over time.
Tips & Tricks:
Alex Hagberg's Tech Tip Tuesday articles
How to mount your Protoform LTC-R Body
Setting static camber
How to mount weight on your chassis Part1
How to mount the rear wing on Protoform bodies
Simple troubleshooting guide
How to mount the battery on your chassis
How to glue your front tires for CRC Black carpet with Eric Anderson
Utilizing Exponential and RMode on the M12S
How to mount weight on your chassis Part2
Team driver Tim Wahl posted some very useful tips on Facebook as he worked through building a new kit.
1- Carbon Parts
2-Suspension
3-Solid Axle and Differential
4-Bulkheads & Drivetrain
5-Driveshaft (ECS & CVD)
6-Front & Rear Suspension
7-Tweak
8-Anti-Roll Bar
9-Battery Fix (OPTIONAL)
10-Bumper & Body
11-Shocks
12-Steering
New Graphite Hubs:
Xray have recently released some additional Graphite hubs for the T4 lineup. The 4° Graphite C-Hub has been out for some time and is known to improve steering on entry, and in general makes the car turn better. This has been the go-to c-hub on asphalt for many on the Xray team, though it is not needed on high bite carpet. The Graphite rear hub tends to make the car more stable, especially on corner entry. We are still working on gathering input on the new Graphite steering block, but for the moment feel that it should improve steering response. All Graphite parts are approximately 1g lighter than the Hard or Medium options.
Option Parts to consider:
XRA301196 T4 Graphite Upper Deck 1.6mm V2
XRA301226 Foam Bumper – Hard - highly recommend
XRA302165 Composite Front Suspension Arm 2-Hole – Hard
XRA302169 Composite Front Suspension Arm 1-Hole – Graphite
XRA302803 1.3mm Front Anti-Roll Bar
XRA303169 Composite Rear Suspension Arm 1-Hole – Graphite
XRA303802 1.2mm Rear Anti-Roll Bar
XRA305137 Steel Solid Axle Driveshaft Adapters - HUDY Spring Steel - highly recommend
XRA305242 Composite Drive Shaft Replacement Cap 3.5mm – Orange – Strong (QTY 4)
XRA305351 Aluminum Wheel Hub – Offset “-0.75mm” – Black (QTY 2)
XRA306191 T4 Graphite + Aluminum Fully Adjustable Battery Holder
XRA308264 4S Spring-Set Progressive C=2.5-2.8 (QTY 2)
XRA308276 4S Spring-Set C=2.7 (QTY 2)
XRA308286 4S Spring-Set C=2.6 (QTY 2)
Specific to Asphalt:
XRA302383 Composite C-Hub Right – 4* - Graphite (ECS)
XRA302384 Composite C-Hub Left – 4* - Graphite (ECS)
XRA308039 Aluminum Progressive Shock System – Set (QTY 2)
Specific to Carpet:
XRA301141 T4 Aluminum Flex Chassis 2mm
XRA302375 Composite C-Hub Right – 6* - Hard ***Modification may be required if they don't have the "ECS" stamp.
XRA302376 Composite C-Hub Left – 6* - Hard ***Modification may be required if they don't have the "ECS" stamp.
XRA303711-O Aluminum Rear Lower Suspension Holder – Front – RF
Recent Setups:
3 July 2016 - Alex Hagberg - European Championship - Asphalt - Mod - 2nd
3 July 2016 - Bruno Coelho - European Championship - Asphalt - Mod - 4th
3 July 2016 - Jan Ratheisky - European Championship - Asphalt - 13.5 - TQ + Win
29 June 2016 - Max Kuenning - Reedy - Asphalt - Mod - 4th
29 June 2016 - Keith Yu - Reedy - Asphalt - 13.5 - TQ + 2nd
29 June 2016 - Eric Anderson - Reedy - Asphalt - 13.5 - 3rd
15 May 2016 - Bruno Coelho - ETS Rd 4 Riccione - Asphalt - Mod - TQ + Win
15 May 2016 - Mattia Collina - ETS Rd 4 Riccione - Asphalt - 13.5 - Win
17 April 2016 - Max Kuenning - MHIC - Carpet - Mod - 4th
10 April 2016 - Bruno Coelho - ETS Rd 3 Wels - Carpet - Mod - 2nd
10 April 2016 - Alex Hagberg - ETS Rd 3 Wels - Carpet - Mod - 4th
10 April 2016 - Jan Ratheisky - ETS Rd 3 Wels - Carpet - 13.5 - TQ + Win
22 March 2016 - Paul LeMieux - Canadian Nats - Carpet - Mod - TQ + Win
22 March 2016 - Luke Pittman - Canadian Nats - Carpet - Mod - 3rd
6 March 2016 - Chris Adams - ROAR Nats - Carpet - Mod - TQ + Win
6 March 2016 - Craig Xavier - ROAR Nats - Carpet - 17.5 - 4th
6 March 2016 - Eric Anderson - ROAR Nats - Carpet - 17.5 - 5th
6 February 2016 - Bruno Coelho - ETS Rd 2 Koblenz - Carpet - Mod - TQ + Win
6 February 2016 - Alex Hagberg - ETS Rd 2 Koblenz - Carpet - Mod - 2nd
31 January 2016 - Alex Hagberg - Snowbirds - Carpet - Mod - TQ + Win
31 January 2016 - Jan Ratheisky - Snowbirds - Carpet - All - See Comments
31 January 2016 - Drew Ellis - Snowbirds - Carpet - 13.5 - 4th
31 January 2016 - Robbie Dodge - Snowbirds - Carpet - 17.5 - Win
13 December 2015 - Bruno Coelho - ETS Rd 1 Hrotovice - Carpet - Mod - 3rd
13 December 2015 - Alex Hagberg - ETS Rd 1 Hrotovice - Carpet - Mod - 4th
13 December 2015 - Olly Jeffries - ETS Rd 1 Hrotovice - Carpet - Mod - 7th
13 December 2015 - Jan Ratheisky - ETS Rd 1 Hrotovice - Carpet - 13.5 - TQ + Win
29 November 2015 - Paul LeMieux - US Indoor Champs - Carpet - Mod - TQ + Win
25 October 2015 - Eric Anderson - Stock Wars - Carpet - 17.5 - 2nd
Print Wikipost
Old 07-06-2015, 09:49 PM
Default Xray T4 2016
Soo less then 3 months to go .......
Been to the last ETS at the Hudy arena myself but didnt notice obvious changes at Bruno-s or Alex-s car.
Anyone already knows what optimised changes we can expect
xraydriver1 is offline
Old 07-06-2015, 11:21 PM
niznai's Avatar
Do the kits come with the new CV driveshafts now? That would be nice.
Other than that perhaps a one piece (Yokomo style, I mean) motor mount?
niznai is offline
Old 07-06-2015, 11:46 PM
Salkin's Avatar
Just hope the shocks/springs, arms, diff/spools and swaybars stay the same.....The ARS could be an option sold seperately, and the ECS's could be standard.
Salkin is offline
Old 07-07-2015, 12:16 AM
Trader Rating: 11 (100%+)
I asked Hagberg this direct at AOC a few weeks back. He said he wasn't sure what could be an inclusion as he wasn't running any prototype parts and he wasn't aware of anything in the pipeline.
He laughed when I suggested maybe PSS shocks!
cplus is offline
Old 07-07-2015, 12:40 AM
daleburr's Avatar
+1, the ARS is rarely used (only at the occasional track), but most drivers use ECSs. I don't imagine they cost much more to manufacture than standard shafts.
daleburr is offline
Old 07-07-2015, 01:21 AM
wtcc's Avatar
This time a 2016 version is not neccessary (in my opinion).
Aftermarket tuning parts from Spec-R, for example the motor mount, made a difference in feeling, but many drivers returned to the original.
What could be an improvement are shortened Spur gear bulkheads. Other than that and the above mentioned ECS the car is nearly perfect. Maybe a material change for the shock bladders would be nice as the swell quite fast.
I am not sure if these small improvements would justify a 2016 version. Lets see what they have in the pipeline...
wtcc is offline
Old 07-07-2015, 02:14 AM
Salkin's Avatar
I would rather let the PSS shock inserts stay an option part to give way for some of the more "permanent" upgrades, like alu end spring cups, carbon front bumper, alu steering etc.
I think the average racer would be more happy with these upgrades than option parts that may or may not work in all conditions.
Salkin is offline
Old 07-07-2015, 02:03 PM
I think including parts where Xray/dealers can make some money afterwards would be starkly in contrast to their business model!
cplus is offline
Old 07-07-2015, 02:04 PM
patorz31's Avatar
A shaft drive car for spec racing to compete with the Awesomatix
patorz31 is offline
Old 07-07-2015, 02:21 PM
There is no need for them to come out with a shaft car. The ETS series has shown the shaft vs belt debate playout on multiple tracks and the results speak for themselves..
Patrick
XCELL is offline
Old 07-07-2015, 02:25 PM
R3VoLuTiOn's Avatar
Trader Rating: 29 (100%+)
I just ask that they seriously consider including the new ecs shafts in the kit WITHOUT increasing kit price.
R3VoLuTiOn is offline
Old 07-07-2015, 02:36 PM
CristianTabush's Avatar
Trader Rating: 13 (100%+)
I want pillow balls inside the suspension mounts. My RX4-13 was still faster than my '14/15 car with the only difference being the suspension mounts. The car has much more steering when used with the pillow balls.
CristianTabush is offline
Old 07-07-2015, 02:54 PM
syndr0me's Avatar
Trader Rating: 32 (100%+)
I'll play. How about a T4'16 carpet edition that includes the following:
Aluminum chassis on par with aftermarket options
Thicker/harder top deck
HD ECS
Graphite arms, with 2 hole in front
Solid servo mount that doesn't extend beyond the back of a shorty servo (ie RADTEC)
Xray's sweet battery retaining system
Solid R/F, split F/R blocks (opposite of current option)
No ARS, spend that money on other upgrades
syndr0me is offline
Old 07-07-2015, 03:27 PM
artwork's Avatar
Trader Rating: 88 (100%+)
HD ECS
solid R/F, split F/R blocks (opposite of current option)
+1
artwork is online now
Old 07-07-2015, 03:49 PM
what car are you talking about?
racenut123 is offline
